drewbab1229
Aug 30, 2021Star
Orbi CBR750 Bad Firmware, cannot roll-back.
Netgear sent Firmware version V4.6.3.6_2.0.48 to my CBR750 which they have determined bad, and I have a few devices that will not connect now that the firmare has been pushed. If I try to roll-back ...
Nov 03, 2021Guru - Experienced User
New FW is out:
drewbab1229 wrote:
Netgear sent Firmware version V4.6.3.6_2.0.48 to my CBR750 which they have determined bad, and I have a few devices that will not connect now that the firmare has been pushed. If I try to roll-back to the suggested version, V3.2.18.2_1.4.14, it is not possible. I have contacted thier support and the best answer they can give me is wait for the next update, really? So Netgear, has now broken my hardware with thier firmware update and will provide me with no option. My device is still under hardware support, and Netgear will not provide me with a new unit that actually works. I can't say I would suggest purchasing Orbi or Netgear products.
