donaldc635
Jul 12, 2022Tutor
Orbi CBR750 Power Supply
The power adaptor for my Orbi 750 modem/router is rated 19v/3.16a. I plan to replace it with a 15v/3.5a power supply. Will this be a problem?
- Jul 13, 2022
Hello plemans,
Thank you for your reply. I was under the impression that he was talking about the RBR750. The correct power rating for the CBR750 adapter that comes in the box is 19V/3.16A. The best practice is to keep the power adapter rating equivalent to the rating of the power adapter distributed by the manufacturer.
Best,
Kevin
Community Team
donaldc635
Jul 13, 2022Tutor
Thanks for the information. My CBK752 needs a 19V adapter. I did more research and I do need a 19V power supply. 15V will not work.
- plemansJul 13, 2022Guru - Experienced User
Glad you looked at yours for the proper voltages.
Is there a reason you want to replace it?
- donaldc635Jul 13, 2022Tutor
I was planning to try a IFI iPower x charger to filter out digital noises, but the company does not make a 19V one. This is supposed to improve the streamer sound for my audio system.
