donaldc635
Jul 12, 2022Tutor
Orbi CBR750 Power Supply
The power adaptor for my Orbi 750 modem/router is rated 19v/3.16a. I plan to replace it with a 15v/3.5a power supply. Will this be a problem?
- Jul 13, 2022
Hello plemans,
Thank you for your reply. I was under the impression that he was talking about the RBR750. The correct power rating for the CBR750 adapter that comes in the box is 19V/3.16A. The best practice is to keep the power adapter rating equivalent to the rating of the power adapter distributed by the manufacturer.
Best,
Kevin
Community Team
