donaldc635
Jul 12, 2022Tutor
Orbi CBR750 Power Supply
The power adaptor for my Orbi 750 modem/router is rated 19v/3.16a. I plan to replace it with a 15v/3.5a power supply. Will this be a problem?
- Jul 13, 2022
Hello plemans,
Thank you for your reply. I was under the impression that he was talking about the RBR750. The correct power rating for the CBR750 adapter that comes in the box is 19V/3.16A. The best practice is to keep the power adapter rating equivalent to the rating of the power adapter distributed by the manufacturer.
Best,
Kevin
Community Team
Jul 13, 2022Guru - Experienced User
Glad you looked at yours for the proper voltages.
Is there a reason you want to replace it?
donaldc635
Jul 13, 2022Tutor
I was planning to try a IFI iPower x charger to filter out digital noises, but the company does not make a 19V one. This is supposed to improve the streamer sound for my audio system.
