Daesania
Mar 03, 2023Star
Orbi CBR750 random outages
Not consistent but at random times I'm losing internet connection. The connection does NOT drop on the modem/router though, it still shows the status up. ISP has come out multiple times (4th was to...
Mar 03, 2023Guru - Experienced User
Does the front LED turn PINK or any of the modem UP or Down LEDs give an AMBER light?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Daesania
Mar 03, 2023Star
A lot of this info was already in my post but i'll post it again.. No there is no color on the orbi. Status lights show up.
The firmware is current, there are no updates available.
Techs have checked the line and it says fine both inside and at the street level box.
Yes there is a splitter, the line splits between my cable box and my modem router.
The line and the splitter are brand new as of today.
The modem has been powered on/off many many times and cycled many many times.
I cannot paste the log currently. It does this sometimes where the log appears blank and will show up later. The errors in my original post are the same errors that show up around the downtime.
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- FURRYe38Mar 03, 2023Guru - Experienced User
Please copy and paste the event log into a word doc then save off as a PDF then use the Choose File button on your next post to attach it.
Who is your ISP?
I see power levels are all over the place and mostly on the low side thought with in spec, channel 32 is -9db and is just too low:
I recommend removing the splitter temporarily to see if the power comes up and the Correctables and Un-Correctables can get to all zeros.
- DaesaniaMar 03, 2023Star
I can't even view the event log. Its blank, eventually it updates, but sometimes it takes awhile. I dunno *shrug*
ISP is cox. The problem with removing the splitter is it removes the ability to access the cable tv, we only have the 1 cable for both internet and tv. I will give that a try later tonight though once the children are in bed and won't be upset about TV being gone.- FURRYe38Mar 03, 2023Guru - Experienced User
Is the FW version v.4 on the CBR?
How was the FW updated on the CBR? Via Orbi app or CBRs web page using a wired PC and web browser?Is Armor, SPC or Traffic Meter enabled on the CBR?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Factory reset the Orbi router and power it off for one minute. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?
