sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
Oct 24, 2021Guru - Experienced User
Great.
Do you have a snippet of the Events Log page as well?
- sen4ikOct 24, 2021Guide
Time Priority Description Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 13:12:30 Notice (6) TLV-11 - unrecognized OID Oct 21 2021 13:12:30 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 21 2021 13:12:32 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 21 2021 13:12:49 Alert (2) CM Certificate Error Oct 21 2021 16:21:53 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 16:21:54 Notice (6) TLV-11 - unrecognized OID Oct 21 2021 16:21:54 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 21 2021 16:21:57 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 21 2021 16:22:14 Alert (2) CM Certificate Error Oct 21 2021 19:55:41 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 21 2021 19:55:42 Notice (6) TLV-11 - unrecognized OID Oct 21 2021 19:55:42 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 21 2021 19:55:45 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 21 2021 19:56:03 Alert (2) CM Certificate Error Oct 21 2021 21:17:03 Critical (3) No Ranging Response received - T3 time-out Oct 22 2021 09:05:12 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 22 2021 09:05:13 Notice (6) TLV-11 - unrecognized OID Oct 22 2021 09:05:13 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 22 2021 09:05:16 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 22 2021 09:05:28 Alert (2) CM Certificate Error Oct 22 2021 10:51:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 22 2021 10:51:31 Notice (6) TLV-11 - unrecognized OID Oct 22 2021 10:51:31 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 22 2021 10:51:34 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 22 2021 10:51:51 Alert (2) CM Certificate Error Oct 22 2021 12:15:16 Critical (3) No Ranging Response received - T3 time-out Oct 22 2021 14:39:51 Alert (2) CM Certificate Error Oct 22 2021 15:12:17 Critical (3) No Ranging Response received - T3 time-out Oct 23 2021 12:57:46 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 23 2021 12:57:47 Notice (6) TLV-11 - unrecognized OID Oct 23 2021 12:57:47 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 23 2021 12:57:50 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 23 2021 12:58:07 Alert (2) CM Certificate Error Oct 23 2021 13:04:30 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 23 2021 13:04:31 Notice (6) TLV-11 - unrecognized OID Oct 23 2021 13:04:31 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Oct 23 2021 13:04:34 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Oct 23 2021 13:04:51 Alert (2) CM Certificate Error Oct 23 2021 17:24:41 Critical (3) No Ranging Response received - T3 time-out
