| Time | Priority | Description |
| Oct 21 2021 13:12:30 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 21 2021 13:12:30 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 21 2021 13:12:30 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 21 2021 13:12:32 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 21 2021 13:12:49 | Alert (2) | CM Certificate Error |
| Oct 21 2021 16:21:53 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 21 2021 16:21:54 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 21 2021 16:21:54 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 21 2021 16:21:57 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 21 2021 16:22:14 | Alert (2) | CM Certificate Error |
| Oct 21 2021 19:55:41 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 21 2021 19:55:42 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 21 2021 19:55:42 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 21 2021 19:55:45 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 21 2021 19:56:03 | Alert (2) | CM Certificate Error |
| Oct 21 2021 21:17:03 | Critical (3) | No Ranging Response received - T3 time-out |
| Oct 22 2021 09:05:12 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 22 2021 09:05:13 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 22 2021 09:05:13 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 22 2021 09:05:16 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 22 2021 09:05:28 | Alert (2) | CM Certificate Error |
| Oct 22 2021 10:51:30 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 22 2021 10:51:31 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 22 2021 10:51:31 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 22 2021 10:51:34 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 22 2021 10:51:51 | Alert (2) | CM Certificate Error |
| Oct 22 2021 12:15:16 | Critical (3) | No Ranging Response received - T3 time-out |
| Oct 22 2021 14:39:51 | Alert (2) | CM Certificate Error |
| Oct 22 2021 15:12:17 | Critical (3) | No Ranging Response received - T3 time-out |
| Oct 23 2021 12:57:46 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 23 2021 12:57:47 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 23 2021 12:57:47 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 23 2021 12:57:50 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 23 2021 12:58:07 | Alert (2) | CM Certificate Error |
| Oct 23 2021 13:04:30 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 23 2021 13:04:31 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 23 2021 13:04:31 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 23 2021 13:04:34 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW |
| Oct 23 2021 13:04:51 | Alert (2) | CM Certificate Error |
| Oct 23 2021 17:24:41 | Critical (3) | No Ranging Response received - T3 time-out |
