sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
Oct 25, 2021Guru - Experienced User
One item you need to ask your ISP about:
These shouldn't be seen in the logs I believe. Maybe why the CBR can't get a seamless connection and can't get a IP address seamlessly from the ISP. The ISP needs to ensure the CBR is getting the config file correctly. Have them check the events log on the CBR as well.
| Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11" |
Triggs21
Oct 25, 2021Star
Any fix on this yet... my system is doing the same thing.
- sen4ikOct 29, 2021Guide
My system just randomly started working. I assume something was up on the Xfinity side. Sorry I don't have any details, I honestly have no idea why it started working.
- Triggs21Oct 30, 2021StarCan you be alittle more specific. I have xfinity as well. What issues were you having. And what did you change, and when was the last signal drop you had...
- FURRYe38Oct 30, 2021Guru - Experienced User
I would presume the ISP had done someting on there side. Most of the time this is a ISP signal issue. If the signals and configuration are not done well or with in specs on the ISP side, makes it hard for ANY modem to work right.
- Triggs21Oct 30, 2021StarThats interesting. Im having the same issue i did before my rma. This model still will not stay connected to xfinity without dropping connectivity. Is there anything I can do to verify isp signal problem? Xfinity has been here several times verifying the signal. Interestingly enough once I connect my older cbr (docsis 3.0) it works fine no disconnects no issues... help
