sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
sen4ik
Oct 29, 2021Guide
My system just randomly started working. I assume something was up on the Xfinity side. Sorry I don't have any details, I honestly have no idea why it started working.
Oct 30, 2021Guru - Experienced User
I would presume the ISP had done someting on there side. Most of the time this is a ISP signal issue. If the signals and configuration are not done well or with in specs on the ISP side, makes it hard for ANY modem to work right.
- Triggs21Oct 30, 2021StarThats interesting. Im having the same issue i did before my rma. This model still will not stay connected to xfinity without dropping connectivity. Is there anything I can do to verify isp signal problem? Xfinity has been here several times verifying the signal. Interestingly enough once I connect my older cbr (docsis 3.0) it works fine no disconnects no issues... help
- FURRYe38Oct 31, 2021Guru - Experienced User
Please post a copy and paste of the modems Connection Status page and Event Log page.
Triggs21 wrote:
Thats interesting. Im having the same issue i did before my rma. This model still will not stay connected to xfinity without dropping connectivity. Is there anything I can do to verify isp signal problem? Xfinity has been here several times verifying the signal. Interestingly enough once I connect my older cbr (docsis 3.0) it works fine no disconnects no issues... help- Triggs21Oct 31, 2021Star
Startup Procedure Procedure Status Comment Acquire Downstream Channel 519000000 Hz Locked Connectivity State Ok Operational Boot State Ok Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectable 1 Locked QAM 256 10 495000000 Hz 13.1 dBmV 40.3 dB 0 0 2 Locked QAM 256 11 507000000 Hz 13.0 dBmV 40.3 dB 6 0 3 Locked QAM 256 12 513000000 Hz 13.1 dBmV 40.3 dB 0 0 4 Locked QAM 256 13 519000000 Hz 13.1 dBmV 40.9 dB 0 0 5 Locked QAM 256 14 525000000 Hz 13.0 dBmV 40.3 dB 0 0 6 Locked QAM 256 15 531000000 Hz 13.0 dBmV 40.3 dB 0 0 7 Locked QAM 256 16 537000000 Hz 13.0 dBmV 40.3 dB 0 0 8 Locked QAM 256 17 543000000 Hz 12.8 dBmV 40.3 dB 0 0 9 Locked QAM 256 18 549000000 Hz 12.6 dBmV 40.3 dB 0 0 10 Locked QAM 256 19 561000000 Hz 12.8 dBmV 40.3 dB 0 0 11 Locked QAM 256 20 567000000 Hz 12.6 dBmV 40.3 dB 0 0 12 Locked QAM 256 21 573000000 Hz 12.5 dBmV 40.3 dB 0 0 13 Locked QAM 256 22 579000000 Hz 12.5 dBmV 40.3 dB 0 0 14 Locked QAM 256 23 585000000 Hz 12.5 dBmV 38.9 dB 0 0 15 Locked QAM 256 24 591000000 Hz 12.1 dBmV 40.3 dB 0 0 16 Locked QAM 256 25 597000000 Hz 12.0 dBmV 40.3 dB 0 0 17 Locked QAM 256 26 603000000 Hz 12.5 dBmV 38.9 dB 2 0 18 Locked QAM 256 27 609000000 Hz 12.3 dBmV 38.9 dB 1 0 19 Locked QAM 256 28 615000000 Hz 12.4 dBmV 38.9 dB 0 0 20 Locked QAM 256 29 621000000 Hz 12.3 dBmV 38.9 dB 3 0 21 Locked QAM 256 30 627000000 Hz 12.4 dBmV 38.9 dB 17 0 22 Locked QAM 256 31 633000000 Hz 12.1 dBmV 38.6 dB 5 0 23 Locked QAM 256 32 639000000 Hz 12.0 dBmV 38.9 dB 0 0 24 Locked QAM 256 34 645000000 Hz 12.0 dBmV 38.9 dB 0 0 25 Locked QAM 256 35 651000000 Hz 11.8 dBmV 38.9 dB 0 0 26 Locked QAM 256 36 657000000 Hz 11.5 dBmV 38.9 dB 0 0 27 Locked QAM 256 37 663000000 Hz 11.0 dBmV 38.6 dB 0 0 28 Locked QAM 256 38 669000000 Hz 10.9 dBmV 38.9 dB 0 0 29 Locked QAM 256 39 675000000 Hz 11.0 dBmV 38.6 dB 0 0 30 Locked QAM 256 40 681000000 Hz 10.8 dBmV 38.9 dB 0 0 31 Locked QAM 256 41 687000000 Hz 10.3 dBmV 38.6 dB 0 0 32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 44 5120 Ksym/sec 17300000 Hz 39.0 dBmV 2 Locked ATDMA 43 5120 Ksym/sec 23700000 Hz 38.8 dBmV 3 Locked ATDMA 42 5120 Ksym/sec 30100000 Hz 39.3 dBmV 4 Locked ATDMA 41 5120 Ksym/sec 36500000 Hz 40.5 dBmV 5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Modulation/Profile ID Channel ID Frequency Power SNR/MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 3 33 693000000 Hz 10.3 dBmV 39.2 dB 1108~2987 0 0 0 2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation/Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0.0 dBmV 2 Not Locked 0 0 0 Hz 0.0 dBmV Current System Time: Sun Oct 31 16:08:44 2021 System Up Time 00:25:22
