| Time | Priority | Description |
| Oct 31 2021 15:31:34 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 |
| Oct 31 2021 15:31:44 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:31:45 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:31:53 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:31:53 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:31:53 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 |
| Oct 31 2021 15:31:54 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:31:55 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:32:04 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:05 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:32:19 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:21 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:32:24 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:25 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 |
| Oct 31 2021 15:32:26 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:26 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:32:31 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:43 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Oct 31 2021 15:32:44 | Warning (5) | Lost MDD Timeout |
| Oct 31 2021 15:32:44 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 |
| Oct 31 2021 15:32:44 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:50 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 |
| Oct 31 2021 15:32:50 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:53 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:32:59 | Notice (6) | CM-STATUS message sent. Event Type Code: 4 |
| Oct 31 2021 15:33:02 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Oct 31 2021 15:33:02 | Warning (5) | Lost MDD Timeout |
| Oct 31 2021 15:33:04 | Notice (6) | CM-STATUS message sent. Event Type Code: 4 |
| Oct 31 2021 15:33:37 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Oct 31 2021 15:34:01 | Notice (6) | CM-STATUS message sent. Event Type Code: 6 |
| Oct 31 2021 15:34:04 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Oct 31 2021 15:34:15 | Notice (6) | CM-STATUS message sent. Event Type Code: 6 |
| Oct 31 2021 15:34:28 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Oct 31 2021 15:34:51 | Notice (6) | CM-STATUS message sent. Event Type Code: 6 |
| Oct 31 2021 15:44:21 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Oct 31 2021 15:44:21 | Notice (6) | TLV-11 - unrecognized OID |
| Oct 31 2021 15:44:21 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Oct 31 2021 15:44:36 | Alert (2) | CM Certificate Error |
