sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
Oct 31, 2021Guru - Experienced User
Ok, Please post a Event log after a while of the CBR being online with out any wire changes.
The Power on the status page maybe too high.
Mines at 0.1dbm range or -1.#Dbm on a few channels on my cable modem.
You might ask the ISP to maybe turn down the power to the modem some.
sen4ik
Nov 03, 2021Guide
And I am back to manually releasing/renewing IP again. Same things as was described in the initial post.
Horrible experience. Especially knowing that the modem I bought is very expensive.
- Triggs21Nov 03, 2021StarIve tried almost everything I can think of..
Plus i am a IT technician so if I cant figure it out im just left to assume we all purchased a **bleep** model orbi. This is my Rma that came shipped with a totally different firmware and im still having the same connection issues that everyone else describes, amazon is flooded with negative reviews on this model orbi as well.
My older Rbk docsis 3.0 orbi works completely fine with no issues on the same coax line.
Technically I shouldn't have to do or change any settings to get this new one to work stable, it should work as advertised just like it did when i first bought it 6 months or so ago.
We dont expect something to just stop working reliably after afew months of usage, especially from a company ive never had an issue with.
Is this new firmware gonna save my 600 dollar paperweight??
Sorry for the rant just so hard to believe there is no saving this extremely expensive setup!! - Triggs21Nov 03, 2021StarNo it kept dropping internet so I had to switch back to my old rbr since my wife works from home... ill have to wait until the weekend to reconnect it and update.
- sen4ikNov 03, 2021Guide
I have updated to the new V4.6.5.8 firmware, and it still drops every 1.5 hours. I am opening a ticket with Netgear to see if maybe they can help.
Called Netgear support.
They told me to change the MTU size to 1486, but they couldn't explain why I should do it.
They told me to update CTS/RTS Threshold to 2347.
And they told me to update wireless channels to the highest number for each channel.
They told me this will fix my issue, which it will not. The issue lays somewhere else other than just tweaking the above.
I will wait another hour for the internet to drop, and will call support again hoping they will take me to the Tier 2 support.
Internet dropped again. I released/renewed and called support again.
I waited for about an hour of the phone, wasn't connected to any support people, and once internet dropped again, the call failed, because I am using wifi calling.
Waited an hour for nothing.
- FURRYe38Nov 03, 2021Guru - Experienced User
Did you factory reset and setup from scratch the CBR updating FW?
Try back tomorrow during the day and if you can, don't use wifi calling.
Try reaching out to a forum Moderator as well.
You may have a faulty CBR that needs replaced. I'd ask about a RMA option if thats availalbe to you.
- FURRYe38Nov 04, 2021Guru - Experienced User
Yes.
- sen4ikNov 08, 2021Guide
I called support today again. The support person reviewed the case and tried to contact Tier 2 support for 40 minutes. After that, I was told to drop a call and wait for a callback within the next two hours as Tier 2 is very busy. One more hour wasted, no solution to the problem.
No one called me back during the day.
I called Amazon, and they agreed to take the item back but charging me $81 restocking fee. I think I will go for it. I can't afford to spend more time with support figuring out this problem.
I purchased another modem today, this time I bought whatever is in Xfinity supported list. And I purchased Asus router. Hoping this will work.
- FURRYe38Nov 09, 2021Guru - Experienced User
- rmarcareDec 27, 2021ApprenticeDid you buy a different modem/router combo? Any idea if netgear will refund if I purchased directly?
- Triggs21Dec 27, 2021StarWe switched to verizon fios and they actually have there own orbi type router/satellite combo with wifi 6. Works wonderful. Very stable with great speeds. 900 up and 900 down. I purchased the orbi directly from netgear.com and they would not entertain a refund even though after 5 months it became unstable. They only wanted to send me an Rma replacement which was just as unreliable. I will never purchase from them again unfortunately. Ive had multiple orbis over the years with no issues and I am also an IT technician so i am more than capable of diagnosing and fixing hardware.
- rmarcareDec 27, 2021ApprenticeI got my Orbi in late November, so within the warranty period. Think I have a chance?
- Triggs21Dec 27, 2021StarThey're customer service is all over seas and very difficult to deal with due to the time difference. Best of luck with that. I gave up. Had to take a loss in order to save my sanity. If anyone ever asks me to recommend them any type of networking solution I cannot comfortably recommend netgear anymore unfortunately. Instead of owning up or admitting they have a faulty product/firmware whatever is causing this issue they put it on the customer and in turn lost alot of loyal customers. Reviews of this product are flooded with complaints and issues on amazon and other retailers that sell this product. They wouldn't even acknowledge that this product has numerous posts on netgears own forum with people who are having all sorts of issues with this model when I spoke to a representative. They should offer us some type of credit or resolution to all the people like us who payed $500+ for a product which is now worthless and unreliable. Im sure once someone reports this to consumer protection agency they will finally do something to actually help the customer instead of trying to sell them on a extended support plan. ✌🏽
- sen4ikDec 27, 2021Guide
I ended up bying Motorola MB8611 modem and ASUS WiFi 6 Router (RT-AX3000). Netgear support is horrible. I calculated total of 14 hours spent on the phone without any luck. Support people just try some lame steps, and than they promise you to call later. And than they call later, and do some more lame steps. From my experience, none of the support people understood the issue in depth - even tier 2 support. The only difference for tier 2 guy was that he used TeamViewer to remotely access my laptop.
- rmarcareDec 27, 2021ApprenticeThank you both for the background, I’m trying to determine my next steps. Maybe a new FW update will come out soon?
- FURRYe38Dec 28, 2021Guru - Experienced User
ALL users need to make contact with NG support if your having FW problems with your CBK systems. NG support or engineering do not visit or post in forums or make anyone aware here of future updates.
https://my.netgear.com/support/contact.aspx
rmarcare wrote:
Thank you both for the background, I’m trying to determine my next steps. Maybe a new FW update will come out soon? - rmarcareJan 07, 2022Apprentice
is reverting back to FW v3 a viable option that actually resolves the intermittent wifi issues?
- FURRYe38Jan 07, 2022Guru - Experienced User
Not officially supported.
However you can try this:
Not sure if that would work or last as the CBR would problaby auto update back to v4.
