sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
hozer1967
Mar 25, 2022Aspirant
Purchased combo router/modem Oct '21 and in the past 2 or 3 months, connectivity drops 4 or 5 times a day requiring a reboot. I updated to the latest firmware v4.6.5.8.
I had Spectrum out here yesterday to test the line and everything looks good on their end. I've used Orbi products for the past 6 or 7 years and never had a problem until I purchased this current model.
rmarcare
Mar 25, 2022Apprentice
supposedly an issue since v4 FW. its frustrating. they eventually sent me a RWA replacement unit and still have the intermittent wifi. FURRYe38 tried a beta FW for CBR750 but said its worse than current FW. hopefully theres a stable beta soon that fixes the issue atejwani
- atejwaniMar 25, 2022Apprentice
Thanks rmarcare for @ mentioning me to thread. CBR750 "beta" firmware, as per FURRYe38 doesn't look good. I tried the Satelite (RBS750) firmware (4.6.7.13) update, it was a mess, and I roll-backed to V4.6.7.5
I will direct message you and we can talk.
Thanks,
Al
- atejwaniMar 28, 2022Apprentice
FURRYe38 - There are clearly issues with
- CBR750
- RBS750 (Does my thread not belong here)?
Secondly, the only solution I can think of is the firmware fix by Netgear - none of the hacks/tweaks work - they rather cripple capabilities.
- FURRYe38Mar 28, 2022Guru - Experienced User
No, you have the CBK750 system which includes the CBR and RBS. All of which have a separate forum for. Please post there.
The CBK and RBK are two different systems.
Please contact NG support and let them know what your experiencing as any fixes will need to come from NG.
https://my.netgear.com/support/contact.aspx
There's nothing here in the forums we can do in regards to that.
Thank you.
- CBR750
