PatronBlair
Nov 07, 2021Aspirant
ORBI CBR750 Static Addresses are not static?
My Orbi CBR750 system currently assigns IP addresses automatically. I have assigned Static Addresses to many of my devices. I allow my grandson, who lives on the other side of the duplex house, to u...
- Nov 07, 2021
First off, STATIC means that IP addresses are assigned ON devices them selves. IP Address RESERVATIONS, which I presume you maybe referring too, are set ON the ROUTER(CBR), not on devices.
I presume you have setup some IP address reservations for these devices ON the CBR itself and ensured these devices are set for Automatic Obtain IP addressing?
When the xbox is ON, press the front power button and hold until it turns off.
Power OFF the printer.
Besure IP address reservations are set for the xbox and printer differently on the CBR.
Reboot the CBR and wait for ready.
Then power ON the Printer and make sure it connects and gets the IP address you reserved on the CBR.
Then power ON the xbox and make sure it connects and gets the IP address you reserved on the CBR.
Nov 07, 2021Guru - Experienced User
