Grdlock
Aug 23, 2021Follower
Orbi CBR750 won't sync with network after ISP activation
So I bought the Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi system AX4200 CBR750, I got it all plugged in and setup through the orbi application. I called my ISP to activate it, after I gave them all the inform...
Aug 23, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
