Tjkg04
Aug 10, 2021Aspirant
Orbi cbr750
I have a Xerox Workcentre6515 that will not connect to my orbi. I've tried everything!
ANYONE HAVE ANY IDEAS?!?!?
Please post about this over in the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
Try disabling AX mode on the CBR750.
Set CTS values to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
Contact the Mfr of this device for help and support regarding there product.
ANYONE HAVE ANY IDEAS?!?!? - FreemaakGuideI recently updared the firmware on my Orbi CBR750 to the latest v4.6.3.6_2.0.48 update. I can no longer establish internet connectivity. Prior to updating my connection was fine with no issues. My ISP says nothing is wrong and the Netgear tech support is no help considering I'm outside my 90 day purchase window.
The cable connection error is with the cable connection continuously failing to connect. I've used new cables and moved it to other cable ports in the house known to work in the past.
Please help.- FURRYe38Guru - Experienced User
Please help.
