TBD12345
May 25, 2022Tutor
Orbi claiming disconnected but Wi-Fi working fine
Hi everyone, I have a Orbi RBR750 with 2 satellites. The orbis are set up as access points while the Orbi router is connected to my Verizon Fios gateway router. The app claims that the Orbi router is...
TBD12345
May 26, 2022Tutor
Hi plemans, thanks for responding
You are correct i actually cannot get rid of the gateway router in general because of the Fios cable (not my choice, but my burden). I currently have the Verizon router doing the routing but turned off the wireless and have the orbis in access mode. I’ve had this set up for over a year now and for some reason I just noticed in the app that I cannot even connect because it says my orbi router cannot connect. I might end up doing a factory reset and re doing the set up
May 26, 2022Guru - Experienced User
It could be related to this:
- TBD12345May 27, 2022TutorThanks!
I was able to solve the issue, I basically just factory reset the Orbi and reconfigured my router as was and started from the beginning by turning off Wi-Fi on the gateway router and re-installing the orbis as access points.. seems to be working fine for now- plemansMay 27, 2022Guru - Experienced User
Glad you got it working!
You might mark it solved so others aren't still trying to fix your issue 🙂
