nsapcor
May 13, 2020Tutor
Orbi connect to Present router
My current router is an Arris furnished by Spectrum. Tech support at Spectrum states they do not support any other routers and will be unable to assist in the future if I replace this with the new Or...
May 13, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
nsapcor
May 13, 2020Tutor
Present equipment is Motorola modem Arris, model TM1602, router by Askey, model RAC2V1K
- FURRYe38May 13, 2020Guru - Experienced User
I believe the ASKEY router can be removed then connect directly to the Arris TM Modem since thats a cable modem. However possible your ISP has special configurations which required the ASKEY Router to be in place.
You can give option#2 a try first if you have access to the host routers DMZ. IF not, try option#3 for the Orbi AX system.
- nsapcorMay 13, 2020Tutor
Thanks for your suggestions,most of which are above my paygrade. Fortunately my grandson is a computer science graduate and may be able to implement the various options without blowing up my house.
There ya go. LOL. Ya, have him help you out with this.
Good Luck.
