jbell0912
Jun 15, 2021Aspirant
Orbi connected but no internet
I recently purchased an Orbi AX 4200 RBK 752 router. It has one satelittle. During setup I can go thru the hole process but when it gets to the end it will not check for new firmare because it is not...
Jun 15, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #3...
jbell0912
I tried that with no success. One of the tech support people had me do that.
- FURRYe38Jun 15, 2021Guru - Experienced User
So is the RBR connected at the modem or at the TPLink router?
For AP mode, the RBR should be connected at the modem with built in router I believe...
Be sure the RBR is connected with the LAN cable on it's YELLOW Internet port in back.
Possible there is a configuration issue between the RBR and your modem or your other router. The TP-Link should not be needed.
- jbell0912Jun 15, 2021Aspirant
TP Link is completely removed from the system. I bought the Orbi to replace the TP. It is def connected with a Lan cable in the yellow port.
Does the RBR show any connection status on its web page at 192.168.1.1 with a wired PC connected to the RBR?
