jbell0912
Jun 15, 2021Aspirant
Orbi connected but no internet
I recently purchased an Orbi AX 4200 RBK 752 router. It has one satelittle. During setup I can go thru the hole process but when it gets to the end it will not check for new firmare because it is not...
jbell0912
I tried that with no success. One of the tech support people had me do that.
Jun 15, 2021Guru - Experienced User
So is the RBR connected at the modem or at the TPLink router?
For AP mode, the RBR should be connected at the modem with built in router I believe...
Be sure the RBR is connected with the LAN cable on it's YELLOW Internet port in back.
Possible there is a configuration issue between the RBR and your modem or your other router. The TP-Link should not be needed.
- jbell0912Jun 15, 2021Aspirant
TP Link is completely removed from the system. I bought the Orbi to replace the TP. It is def connected with a Lan cable in the yellow port.
