devdeep
Sep 02, 2022Guide
Orbi connection directly to FTTP ONT
After some discussion, have decided to drop the landline requirement.
This raises the possibility of connecting the Orbi 353 directly to the ONT and go with a FTTP supplier for 1Gb (or around). Are there issues with a direct connection? I appreciate the Openreach engineer will only connect it to the isp hub - I can then remove it if required. I guess ONT is a form of "modem" so a third party modem is not required.
Has a power off for 1 minute then back ON with the ISP ONT and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Something to ask the ISP about to ensure that's supported. Ask about any ISP configurations that maybe needed.
