stein97
Aug 27, 2020Aspirant
ORBI DHCP
I have RBR750 with latest firmware. Few questions on DHCP: DHCP Lease time, how long is it? Does everyone make reservations for all thier devices? After I add a reservation do I need to hit...
- Aug 27, 2020
stein97 wrote:I have RBR750 with latest firmware.
After I add a reservation do I need to hit apply and reboot the router or does the reservation take effect?
I realize that I cannot change the DNS ip on the DHCP as this would defeat the purpose of the Netgear Armour feature.
thanks
You can use the default DHCP lease time with no problem. The Orbi usually uses the same IP address for the device, once registering it.
Some people make IP reservations, others don't. My practice is I make reservations for cameras, some gaming systems and troubled PCs, that keep wanting to default to a Microsoft 69 IP address.
Follow the instructions when adding an IP reservation. The Orbi will reboot if needed.
I don't use Armor, as I feel it slows down the system. I prefer to apply protection to each device that needes it. Primarily working with Windows OS, I use Windows Security as it is as good as anything on the market, rarely gives false positives, and is updated more often than most 3rd party protection. Of course businness environments may be a different situation.
CrimpOn
Aug 27, 2020Guru - Experienced User
stein97 wrote:DHCP Lease time, how long is it?
Most of the participants in this forum have the original, WiFi5 residential Orbi products. There is a separate community forum for the new AX products: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax There are some differences in the new product that we may not be aware of, so posting in the AX forum is more likely to be aware of those differences.
My Orbi lease time is 24 hours, which is pretty standard. I agree with Mstrbig that device reservations are an individual practice. I am like him in that I like to assign IP's to devices that are "permanent" and let more transient devices get an IP from the DHCP pool. Of course, clicking "Apply" is a requirement, but not a Reboot.
I cannot speak for the AX product, but my experience with the older Orbi is that DHCP management does not behave the way I expected it to. As long as you create an IP reservation which matches the IP address a device has already received, things go well. However, if the reservation is for a different IP than the one the device already has, I have found that devices often will not change.
- stein97Aug 27, 2020Aspirant
Going over the other forum!
thanks
