Dewiz_45
Feb 23, 2023Tutor
Orbi disconnects iPhones only
I had purchased the Orbi RBR750 a few years ago because Netgear was having a sale on them . I had an Orbi RBR50 before this that ran flawlessly, 0 issues which I ended up giving to my brother so when ...
Apr 01, 2023Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How many RBS are deployed?
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Dewiz_45
Apr 01, 2023Tutor
I did everything you told me to do, rebooted the router & reconnected my satellites once the router was done rebooting.
As for my neighbors WiFi only 3 show up
My square footage for my house is just shy of 3,000 and I have 1 satellite downstairs with my router and 2 upstairs. I
- FURRYe38Apr 01, 2023Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- FURRYe38Apr 04, 2023Guru - Experienced User
For that size of home, just the router and 1 RBS is enough.
Too Much Wifi: https://youtu.be/UR0viMLISz4
