drdre892001
Jan 25, 2025Aspirant
Orbi dropout - why can’t it reconnect itself?
Sometimes my fibre internet modem loses connection … when it does the RBKE962 Orbi goes red. But when the fibre internet gets back up, the Orbi doesn’t reconnect automatically, you have to turn the O...
Jan 26, 2025Guru - Experienced User
What FW version is loaded on the system?
Routers are meant to be online and connected 24/7, a reboot causes all devices to get disconnected. Should never been needed.
If there is a problem on the ISP side then this would need to be checked by the ISP.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
There maybe some interoperability issue between the RBR and your ISP device that isn't been handled right between them when that happens. I've not seen that with my Orbi systems, however I have Cable ISP services here.
drdre892001
Jan 28, 2025Aspirant
I’m using the RBKE962 ORBI system with firmware v7.2.6.21. (Not using .31 as users reporter issues with that)
I’m using the Ethernet cable that came with the Orbi.
I’ve contacted my ISP and they’ve confirmed my ISP fibre modem is not dropping out. It’s been connected for weeks.
So it looks like the issue is my Orbi RBR is dropping out and I have to manually reboot it.
I’m guessing I have to factory reset it again? It seems unstable
- FURRYe38Jan 28, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Had the system been ever updated to v.31 FW?
- drdre892001Jan 30, 2025AspirantIt’s an NBN Fibre box G-240G-P
I’ve attached a pic of it (not mine but I found on the internet)
Currently there is a small Cat6 30AWG cable connected from the NBN Fibre box to the RBR960. I’ve just purchased a short Cat6A STP 26AWG cable from Amazon to see if that will improve things.
My RBR960 and RBS960 did use to have the .31 firmware but I downgraded the firmware to .21 on both and done a factory reset.- FURRYe38Feb 02, 2025Guru - Experienced User
Any progress on this?
