Dsteve
Feb 21, 2021Tutor
Orbi Ethernet Backhaul Setup
Trying to set up my Orbi RBK853 for enthernet backhaul. No issues with the satellites. Question regarding the connections for the router with ethernet backhaul. Is it a single ethernet cable fr...
Feb 21, 2021Guru - Experienced User
WAN port is always to the ISP modem services.
- DsteveFeb 22, 2021Tutor
For the WAN connection, does it have to be directly to the modem or can be connected via a switch or switches?
My home setup has mutliple unmanaged/managed switches and VLAN's to control access.
Modem>>>D-Link DSR250>>>>netgear GS116 which everything in the house.
For the Orbi router connection i am going:
D-LInk DSR250>>>>Netgear GS308e>>>>Orbi Router
Basically can i connect both connects from the ORbi router WAN & LAN to the same switch?
Note, right now i have the Orbi router just connected to the LAN, everything seems to work great, but when i login to router via browser i seem to have an issue with firmware update, says theres not internet connection.
Thanks
- FURRYe38Feb 22, 2021Guru - Experienced User
This will work:
D-LInk DSR250>>>>>2 WAN port on Orbi Router>>>>LAN port from Orbi Router>>>>>2 Netgear GS308e switch
I guess i should have mentioned i have a VLAN currently setup on one port of the GS308e>>>2 the DSR-250, to seperate off my work laptop from my home network.
Putting the GS308e after the ORbi router is that going to create any issues?
Sorry just know enough to be dangerous setting up this stuff.
Thanks
