Dsteve
Feb 21, 2021Tutor
Orbi Ethernet Backhaul Setup
Trying to set up my Orbi RBK853 for enthernet backhaul. No issues with the satellites. Question regarding the connections for the router with ethernet backhaul. Is it a single ethernet cable fr...
Dsteve
Feb 25, 2021Tutor
Ok progress and better understanding, some of obvious now!!! :)
Router connected to the WAN port, auto firmware checks now working.
Just realized the attached devices is really meant for the devices connecting wirelessly or through the LAN ports only. That is working as expected, but liked being able to see everything on my home network using the LAN Port. :)
Bottom line i need to get an extra Cat5e cable downstream of the DSR-250 to a diiferent switch to connect the ethernet backhauls.
Just remembered the house was wired with a spare Cat5e cable which i think i can connect back to the basement enclosure, if i use that the thernet backhaul should work ?
See attached a couple of possible setups, i think either will work, but is less desireable due to distance from router.
Will either work?
Thanks again for the help.
Dsteve
Feb 25, 2021Tutor
Netgear does not allow more than 1 attachment!!!
