mrbobcc
Jun 06, 2023Aspirant
Orbi factory reset
Ok no security question. So simply 1. unplug modem 2. put orbi back to factory reset 3. plug in modem 4. do a Orbi setup like it is new use ssid and password off the bottom of the Orbi 5 o...
CrimpOn
Jun 06, 2023Guru - Experienced User
No. If the WiFi devices were configured to use a previous WiFi system, then the new system should be configured to use exactly the same credentials. This will cause devices to connect automatically.
