mrbobcc
Jun 06, 2023Aspirant
Orbi factory reset
Ok no security question. So simply 1. unplug modem 2. put orbi back to factory reset 3. plug in modem 4. do a Orbi setup like it is new use ssid and password off the bottom of the Orbi 5 o...
Jun 06, 2023Guru - Experienced User
So simply
1. unplug modem
3. plug in modem
4. do a Orbi setup like it is new use ssid and password off the bottom of the Orbi< configure old SSID name and pass word here so that devices will auto connect to the Orbi system once it's setup and you turn off the out going router system.
5 old attched devices should migrate to the "new" Orbi
Is that the steps?
Thanks again
Robert
