HansWest
Jun 06, 2022Aspirant
Orbi firmware downgrade
I have an orbi rbk852 firmware V4.6.8.2. because I had problems I wanted to downgrade to V4.6.3.16 I downgraded the satelite but now I can't connect to the router. The router is still the new version...
- Jun 06, 2022
Yes. I would reset the RBR first and set it up from scratch and get it running. Once it's up and running, bring the RBS to same room or near the RBR and turn it on. Factory reset and once it starts to pulsate WHITE in front, press the sync button on the RBS then press sync button on RBR or use the RBRS Add satellite web page feature.
Jun 06, 2022Guru - Experienced User
did you try factory resetting it?
HansWest
I have now only updated the satellite. but it no longer makes contact with the router. do the versions of the firmware have to be the same or can they also be different. I don't dare to downgrade the router now. I reset the satellite but can't connect to the router
