StratNetworker
Jun 09, 2020Aspirant
Orbi firmware update blocks https
Just updated to firmware V3.2.15.25_1.3.15 last night, and now I can't just type https://192.168.1.xxx to access my NAS. The laptop is wired and the NAS is wired, but the Orbi is my DHCP router. ...
Jun 11, 2020Guru - Experienced User
Any progress on this?
Does HTTP vs HTTPS and IP address of NAT work?
As suggested, make sre the NAS is using a static IP address set ON the NAS or you can set a IP address reservation for the NAS ON the router. I use static IP addresses on my two NAS so the know the IP address doesn't change. HTTP works fine for my needs.
Disable any amror features temporarily to check this.
StratNetworker wrote:Just updated to firmware V3.2.15.25_1.3.15 last night, and now I can't just type https://192.168.1.xxx to access my NAS. The laptop is wired and the NAS is wired, but the Orbi is my DHCP router.
Any thoughts why?
Thanks!!!
