Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
xnolightx
Mar 10, 2020Star
I did try that, but unfortunately it did not resolve the issue. Any attempts to revert to the previous firmware version seems to ultimately put me back on this version which completely renders the device useless.I have a case open with support at the moment and I'm waiting on the line for some assistance.
Mar 10, 2020Guru - Experienced User
Is the RBS wirelessly or wired to the RBR?
Hopefully support will help out.
xnolightx wrote:I did try that, but unfortunately it did not resolve the issue. Any attempts to revert to the previous firmware version seems to ultimately put me back on this version which completely renders the device useless.I have a case open with support at the moment and I'm waiting on the line for some assistance.
