Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
xnolightx
Mar 10, 2020Star
I would be happy to, but I actually had to pull my system down entirely and replace it with my previous Google Wifi system. I'm in the middle of planning for a product release and I won't have the time over the next couple of days to put the system back up.
What seemed to bewilder me about this is that even after reverting back to 3.2.9.1_2.4 I had the very same issues. I'm confident that I did not start seeing this issue until 3.2.11 was released, but now my system is completely toast. I'm truly scratching my head over this one, but I agree logs should help NG sort this out.
Has anyone else reverted firmware, and if so are you still seeing the issues like I am seeing?
ehl1
Mar 10, 2020Guide
I have tried to manuall downgrade to 3.2.9.2, did the RBS850 first then the RBR850 just as instructed, then did hard reset on both.
Upon reboot, both are back immediately on 3.2.10.11 - does this mean both units reupgraded back to 3.2.10.11, or did the 3.2.9.2 downgrade not take?
Anyone with similar problems?
- FURRYe38Mar 10, 2020Guru - Experienced User
Be sure to check the CTS and RTS values Under Advanced Tab/Advanced Settings/Wireless Settings. Set them from 64 to 2347 for both 2.4G and 5G radios. Save and apply the setting. Reboot the RBR, RBS and all of your wifi devices.
ehl1 wrote:I have tried to manuall downgrade to 3.2.9.2, did the RBS850 first then the RBR850 just as instructed, then did hard reset on both.
