Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
dragonmastr
Mar 10, 2020Aspirant
I'm having a lot of connection issues with 3.2.10.11 as well. Downgrading to 3.2.9.2 resolves those connection issues. Does anyone know how to disable the firmware auto-update in order to prevent the router from re-installing 3.2.10.11? I did some Google searches but the answers I found so far only apply the original Orbi router and not the AX6000.
Mar 10, 2020Guru - Experienced User
Be sure to check the CTS and RTS values Under Advanced Tab/Advanced Settings/Wireless Settings. Set them from 64 to 2347 for both 2.4G and 5G radios. Save and apply the setting. Reboot the RBR, RBS and all of your wifi devices. Was noticed that 64 is not a good value on v11 which it should be 2347. May help solve some wifi issues.
Disabling of auto update was never supported officially though others found ways. You can try those on Orbi AX. Doubt it will work.
I've already asked NG to review this and asked them to pull this version of FW from the update servers. Will have to see if that happens.
If you can't seem to get your system back to stable, please contact NG support. Open a support ticket.
dragonmastr wrote:I'm having a lot of connection issues with 3.2.10.11 as well. Downgrading to 3.2.9.2 resolves those connection issues. Does anyone know how to disable the firmware auto-update in order to prevent the router from re-installing 3.2.10.11? I did some Google searches but the answers I found so far only apply the original Orbi router and not the AX6000.
