Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
Mar 13, 2020Guru - Experienced User
I see NG just posted v10.11 acutal files for download:
https://kb.netgear.com/000061769/RBR850-RBS850-Firmware-Version-3-2-10-11
Users may want to download these and apply them manually using IE11 or FireFox. I highly recommend a factory reset on the entire system after the RBS and RBR have been updated with these files. RBS first, then RBR lastly. Set up from scratch.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
- FURRYe38Mar 13, 2020Guru - Experienced User
Got word from a forum moderator. NG will be removing v10.11 from there update servers and from the support site. NG is still working on this. Please be patient.
- DoctorAMar 13, 2020Luminary
Thank you.
I am still using Firmware v3.2.10.11 and didn't go back to prevous version.
After few restarts my 2nd RBS50 is working fine.
All my satellites are connected with wired method. My wired PC has a problem only with one
backgammon site dropping connection.
My CTS and RTS values were at 64 and I changed it to 2347.
What improvements should I expect?
- warpdagMar 14, 2020Apprentice
I too use wired backhaul, the new firmware seems to make the wired backhaul connection unstable (blue light on all the time, briefly flips to magenta once in a while). That's after the router updated to v3.2.10.11. Do you see the same thing? It doesn't look like many of us use wired/ethernet backhaul around here.
- DoctorAMar 14, 2020Luminary
Yes, I see the same thing. The wired/ethernet backhaul was very stable between AX 6000 router and satellite before Firmware v3.2.10.11. Also RBS 50 satellites must be connected only wired and was very stable. Now RBS 50 connected to RBS 850 becomes magenta and needs restart of the RBS 850.
My second RBS 50, which is connected to the main 850 router, is more stable.
