Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
Mar 13, 2020Guru - Experienced User
I see NG just posted v10.11 acutal files for download:
https://kb.netgear.com/000061769/RBR850-RBS850-Firmware-Version-3-2-10-11
Users may want to download these and apply them manually using IE11 or FireFox. I highly recommend a factory reset on the entire system after the RBS and RBR have been updated with these files. RBS first, then RBR lastly. Set up from scratch.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
Got word from a forum moderator. NG will be removing v10.11 from there update servers and from the support site. NG is still working on this. Please be patient.
