Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
Abesne
Mar 18, 2020Initiate
This is what I have done to fix my disconnect issues. I can confirm that this fix has worked for the last 2 days, and I have experienced 0 disconnects since I have made the changes. My RBR850 is setup in router mode.
- I downgraded the router and satellite firmware to version 3.1.5.23 ( that fixed the problem) intermediately
- Changed RTS/CTS to 2347
- blocked the following
- http.fw.updates1.netgear.com
- http.fw.updates1.netgear.com/rbs/default/ww
- https://http.fw.updates1.netgear.com/rbs/default/ww
- updates1.netgear.com
Go to http://<router IP address>/debug.htm and check "enable telnet"
- Telnet into the router and run the following
nvram set orbi_auto_upgrade=0
nvram set auto_check_for_upgrade=0
nvram set auto_update=0
nvram set auto_upgrade_enable=0
nvram set install_fw_upgrade_latest=0
nvram set ver_check_enable=0
nvram commit
Now when I log into the router and check the firmware versions my RBR850 is on 3.1.5.23 and my RBS850 is on 3.2.9.2 (the satellite upgraded on its own after the downgrade). The different firmwares between the satellite and the router have not been an issue. When I go to the firmware section of the router and it check for new firmware I am getting a "service unavailable" for the RBR850.
