angelicbiscuit's avatar
Nov 10, 2023
Orbi Guest Network randomly switches itself off.
Hi,
I have enabled the Orbi Guest network at my business however it seems to just randomly stop working and I have to open the app and re-enable it and then it works fine again. Im not sure what could be causing this. the network works fine, its just the guest network feature that switches itself off.
Thanks.
1 Reply
  • FURRYe38's avatar
    What model Orbi do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
