den452001
Nov 23, 2020Aspirant
ORBI Hair Pinning
I have a server that unable to access external IP Addresses when connected to LAN. For example External Ip Address: 108.111.111.222 Internal Ip Address. 192.168.1.100 When connected to the same ne...
Nnyan
Nov 26, 2020Tutor
So I'm not exactly sure if I understand your question, when you say hairpinning do you mean NAT loopback? Your post doesn't seem to be describing a hairpin situation but that could be my misinterpretation. Correct me if I'm wrong here:
108.111.111.222 WAN (ISP) port address on RBR850
192.168.1.100 Ubuntu Server
How exactly are you connecting everything in your two different scenarios? Are you using VLANs ?
