Maxi_orbi
Apr 15, 2024Aspirant
orbi has issues (model : RBR850 , serial number:687A1C7EA0C82
My orbi has an issue; in fact, I can't locate it on my orbi app, and the router doesn't connect to the internet. Model: RBR850, serial number: 687A1C7EA0C82, and I can't log in to it. I really don't k...
Maxi_orbi
The firmware or version that is currently loaded is version: 2.35.0.336
The product number (PN) of the internet provider (starlink) is :34600000-510/C
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
I’m using the LAN cable that came with the orbi router CAT.5E
Any front LED indications?
Yes, it turns on LED indicator
Maxi_orbi
MODEL: UTR-211
