faxfan2002
Jun 11, 2023Aspirant
Orbi internet access from different IP ranges
The connection is - Internet -> Orbi -> Switch -> WAN Checkpoint 1550 LAN -> Device The orbi, switch and WAN checkpoint sit in the 192.168.1.0/24 range. The Checkpoint LAN range is 10.146.1.0...
Jun 11, 2023Guru - Experienced User
Contact the Mfr of that WAN Checkpoint device.
Put the WAN checkpoint device IP address it gets from the Orbi into the Orbi's DMZ.
- faxfan2002Jun 11, 2023Aspirant
Thanks, marking the checkpoint as the DMZ didn't work, still need to NAT. Just to be clear this issue is NOT specific to the checkpoint, I can swap the checkpoint for cisco device and have exactly the same issue. HOWEVER if I swap the orbi out for, example, a draytek or cisco device it works.
I assume Orbi is dropping traffic that isn't part of it's "LAN" range.
- FURRYe38Jun 12, 2023Guru - Experienced User
What happens if you use the Orbi system in AP mode?
