faxfan2002
Jun 11, 2023Aspirant
Orbi internet access from different IP ranges
The connection is - Internet -> Orbi -> Switch -> WAN Checkpoint 1550 LAN -> Device The orbi, switch and WAN checkpoint sit in the 192.168.1.0/24 range. The Checkpoint LAN range is 10.146.1.0...
Jun 11, 2023Guru - Experienced User
Contact the Mfr of that WAN Checkpoint device.
Put the WAN checkpoint device IP address it gets from the Orbi into the Orbi's DMZ.
faxfan2002
Thanks, marking the checkpoint as the DMZ didn't work, still need to NAT. Just to be clear this issue is NOT specific to the checkpoint, I can swap the checkpoint for cisco device and have exactly the same issue. HOWEVER if I swap the orbi out for, example, a draytek or cisco device it works.
I assume Orbi is dropping traffic that isn't part of it's "LAN" range.
- FURRYe38Jun 12, 2023Guru - Experienced User
What happens if you use the Orbi system in AP mode?
