Dode0
Aug 25, 2021Aspirant
Orbi keeps dropping out, can’t connect a lot of devices
I upgraded my home network last week with the orbi 350 + 2 satellites. Had nothing but issues with it since. It will randomly drop out for a couple of minutes every couple of hours, some devices are c...
Aug 27, 2021Guru - Experienced User
Any progress on this?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Dode0
Aug 28, 2021Aspirant
I hardwired everything in to the orbi satellites, now the satellites are loosing connection to the main one, first one is 25ft away, one brick wall, the free sky modem didn’t have any issues with this distance. It’s useless, I’m sending it back.
- FURRYe38Aug 28, 2021Guru - Experienced User
Good Luck.
