RevHoney
Dec 26, 2019Tutor
Orbi Location Services
I bought an Orbi RBR50 v2 router with sattalites and connected it to a Netgear CM 1000 cable modem. Since disconnecting my Apple AirPort Extreme and connecting the new Orbi, however, the location ser...
RevHoney
Dec 26, 2019Tutor
Also, I'm trying to get rid of the Airport. That's why I bought the Orbi. Is the Orbi unable to provide a location by itself? If that's the case, I'll likely return it.
Dec 26, 2019Guru - Experienced User
The Orbi should be providing location or passing thru the services for your devices. Mine does. I have a CM1100 modem.
What DNS are you using? ISP provided or something different? You might try 1.1.1.1 and 9.9.9.9 on the RBR to see if this changes anything..
Be sure to not enable Armor or Circle when you go to facory reset the RBR and setup from scratch.
I would also power OFF the ISP modem during the reset of the RBR for 30 seconds then back ON. Then walk thru the setup wizard on the RBR with a web browser.
- RevHoneyDec 26, 2019Tutor
FURRYe38,
Thank you for the advice. I've had the device over two weeks now and spent over a week in chats with Netgear trying to resolve the issue: updating several firmware packages, rebooting the router, performing a factory reset on the router and setting it up again from scratch, tried various DNS addresses, trying many other settings, and more. Finally, Netgear admitted the device might be defective and offered on December 18 to send me a replacement. It took them a week, apparently, to locate that replacement, which should be here tomorrow.
I will do as you suggest and walk through the set-up wizard, turn off the modem (Also a Netgear CM1000), and cross my fingers. I have already turned off Armor and Circle. I appreciate the help. I'll let you know what I find out, but I admit, I've been pretty frustrated with Netgear's response.
RevHoney
- FURRYe38Dec 27, 2019Guru - Experienced User
Let us know how it goes.
- RevHoneyDec 29, 2019Tutor
My set up:
RBR50v2 with 2 satallites and a CM 1000 modem. Running Firmware version 2.5.1.8
I have now installed the replacement router that Netgear sent me assuming my original was defective. I still have no location services without using an Apple Airport Express. No location service on either of my MacBook computers, my 2 iPhones, or my iPad
I'm beginning to think it's a router setting. The Airport Express is merely plugged in to power. It's not installed with an ethernet cable, so it must be getting the location information wirelessly somehow from the router, but then why do none of my devices see that as well.
I don't pretend to be a tech, but I'm trying to get this set up.
Thanks all for any help you can provide.
