RevHoney
Dec 26, 2019Tutor
Orbi Location Services
I bought an Orbi RBR50 v2 router with sattalites and connected it to a Netgear CM 1000 cable modem. Since disconnecting my Apple AirPort Extreme and connecting the new Orbi, however, the location ser...
schumaku
Dec 30, 2019Guru - Experienced User
RevHoney wrote:If I connect an old Airport Express to one of the satellites, I get the location services back, but without that, nothing. None of my devices can determine their location.
This is because already the presence of a (known to the location service cloud) wireless device (SSID, wireless MAC address) in the vicinity is sufficient so the cloud based location services can create a correlation and provide location service.
At least your iPhones should be able to get the exact location from the built-in GPS/Glonass modules, unless the devices are located in the underground or to far away from the building hull/windows. If these can gain satellite location information while in the wireless range, and you have not decided for not sharing location data (that would be a show stopper!), the cloud location databases will be updated with your new Orbi wireless name, MAC address, and location. Of course, this process does take a while - and it has to happen for the Orbi router and the Orbi satellites due to the different MAC addresses.
This is - among the re-config hassles for the possibly many wireless devices - the key reason why we suggest not to change the wireless name (SSID) when installing a new router or wireless system, and carry forward the existing name and wireless security key.
-Kurt
