evry1lovej
Aug 27, 2022Follower
Orbi mesh 6e best setting for fast speed and low ping
What is the best configuration to get most Out of the mesh.
Aug 28, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Depending on size of home, you may not need many RBS deployed.
Usually default settings works well.
Ethernet connect the RBS if you have that support in the home.
CAT6 is recommended. CAT6A STP is recommended for 2.5Gb connections.
