Wizzard370
Oct 16, 2023Tutor
Orbi mesh and Google Pixel watch 2
Just bought Google Pixel watch 2. This, I understand, only runs on 2.4Ghz. I tried various options but will not connect to the Orbi 353 mesh. I keep on getting password error. Orbi assigns the freque...
- Oct 16, 2023
A couple things.
1. is the watch updated on its firmware? Some early versions of pixel firmware had issues with mesh systems
2. cheat. If it connects to the asus, setup the asus (or your phone's hotspot) with the same ssid/password as the orbi. Once the watch connects, it should remember the ssid and auto-connect to the orbi after you shutoff the asus or hotspot.
Oct 16, 2023Guru - Experienced User
A couple things.
Wizzard370
Oct 16, 2023Tutor
Thanks a lot for this.
1. Upgrade is done but did not help
2. Will try and set the SSID / password on Asus AP the same as the Orbi router. One question - can a system have two same SSID / password? I appreciate one is a router and one is an AP
