NGBRenc
Nov 22, 2020Follower
orbi mesh network and century link router / modem - Cannot connect
I have just started with Century link fiber and I cannot get the Century Link Modem / route (4000) to connect succesfully with ORBI router (AX4200) RBK753S. Century link suggested a bridge setup wit...
Nov 22, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
