jscrna
Jun 12, 2021Follower
Orbi Mesh Router
Orbi Mesh Wi-Fi 6 I just ordered an Orbi RBK752 to replace a Nigthawk R7000. When I set up the Orbi, I am going to give it the same User Name and Password as the Nighthowk. Will the devices conne...
- Jun 12, 2021
jscrna wrote:Orbi Mesh Wi-Fi 6
I just ordered an Orbi RBK752 to replace a Nigthawk R7000. When I set up the Orbi, I am going to give it the same User Name and Password as the Nighthowk. Will the devices connected to the Nighthawk, automatically connect to the Orbi? I would hate to have to reestablish the connected devices.
Thanks, Jeffrey
Yes, they will.
PaulHalstead
Jul 03, 2021Aspirant
I will be getting a direct connect fiber (CenturyLink). I want internet only-no cable. It looks like I don't need a CenturyLink modem at all. The "Orbi Whole Home Tri-band Mesh WiF 6 System (RBK852) would be enough to get WiFi from the active fiber connection. Is this correct???
Jul 03, 2021Guru - Experienced User
You need to ask your ISP if any kind of modem or gateway router they have may be required first and if not, what is needed to use on the RBR as the internet interface for the ISP service.
PaulHalstead wrote:I will be getting a direct connect fiber (CenturyLink). I want internet only-no cable. It looks like I don't need a CenturyLink modem at all. The "Orbi Whole Home Tri-band Mesh WiF 6 System (RBK852) would be enough to get WiFi from the active fiber connection. Is this correct???
