mct1981
Jan 22, 2021Follower
orbi mesh system and sky q
Hi,
I'm looking to purchase the RBK853.
I currentlt have sky broadband with a sky Q main box and 2 mini's.
I having difficulties with loss of connectivity with the mini box's and various attempts to solve this have failed.
I have read about installing the RBK853 system and plugging an ethernet cable from one of the satellite/nodes in the mini's and main box and then disbling sky wi-fi on router and mini boxes.
Does anyone have any experince of this and if so was it successful?
Thanks
1 Reply
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThe Minis probably need to be remain connected to the SkyQ. Contact your ISP for help and informatio regarding there product.
