tyandbrand
Jan 01, 2023Follower
Orbi mix
Hello, I currently have an Orbi rbs850 ax6000 with 2 satellites. Can I add another satellite that is a duodenum model?
Jan 02, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Only other model RBS that are compatible is the 750 and 350 series. Other non Orbi wifi extenders that are compatible as extenders are EX7500/7700/8000 and EAX series extenders.
tyandbrand wrote:
Hello,
