HouTex1776
Apr 13, 2021Aspirant
Orbi model #AX4200 - new to Orbi and looking for some setup advice
Sorry, if I double posted this but I believe I had it in the wrong area to start with.
Hello, I recently purchased the Orbi AX4200 system to cure dead spots in our home.
We have Xfinity here with an all-in-one modem/router. (Vendor: Technicolor, Model: CGM4140COM) At least I think that is correct. I logged into http://10.0.0.1 and pulled the info from there.
I've been doing some reading as to how to connect but didn't see anything specific to this particular model from xfinity. I can see in the xfinity gateway where I can put the router into bridge mode which is what I read as the correct thing to do. I also saw something about turning off the WiFi hotspots but don't see anything in the settings to do that? Do I need to call Xfinity for that?
I also read about connecting the Orbi router and satellites all together first before connecting to the Xfinity modem.
Basically I'm just curious what the best way is to go about this in a step by step manner. I don't feel like screwing up our whole network as we have children at home doing virtual school and I also work from home so...lol
Appreciate any tips or insight anyone that knows what they're doing can provide.
If you need any additional info just let me know.
- res1983Guide
If you are able to log into your router/modem, I would try to locate the feature to turn off WiFi on the router. (I don't have Xfinity but have used other carriers with same setup). If you don't want turn off the Xfinity Wifi, then you can always run your units in AP mode.
Does that make sense?
- HouTex1776Aspirant
I think so...basically run the Orbi router in access point mode and then have the orbi satellites connect to the Orbi router that way?
What's the more efficient way to set it up? I need to keep the xinifty modem because it's cable and that's how I get my signal. I don't really have an issue with speeds just the dead spots.
I honestly don't care about using the xfinity router if the Orbi router will perform better.
You can either let the ISP modem work as a router and configure the RBR for AP mode and let the modem router do all the IP addressing, or you can configure the modem for bridge mode, then set the RBR for router mode and the modem in bridge mode will just pass the internet services to the RBR and the RBR will handle the IP addressing and everything else.
HouTex1776 wrote:Sorry, if I double posted this but I believe I had it in the wrong area to start with.
if the modem can be fully bridged, then the wifi on the modem should be fully disabled as well when in bridge mode. Something to contact the ISP about for additional help and information regarding there equipement.
Yes you can do that. It's recommended to turn OFF the modem and orbi host router (RBR) for 30 seconds, connect the two together, then turn ON the modem first then RBR. Should connect and get internet services after that.
30ft distance or more between the RBR and RBS is recommended.
